- English
- Cameras
- Can you turn off the spotlight on the Arlo Essenti...
Can you turn off the spotlight on the Arlo Essential Spotlight Camera?
I am looking at buying a Arlo Essential Spotlight Camera to use in my house with an existing Arlo Pro 3 set-up and was wondering if you can turn the spotlight off. Since it's in the house I don't want a spotlight going off when I get in the middle of the night.
Dan
HI @DMOA
Yes you can. To activate or change the Arlo camera's spotlight behavior:
- Launch the Arlo app or log in to my.arlo.com.
- Tap or click Settings > My Devices.
- Select your Arlo camera.
- Tap or click Video Settings > Low Light Settings.
- Tap or click the slider next to Spotlight.
You can move the slider under Brightness to adjust the brightness of the spotlight.
You can also change the behavior of the spotlight to Constant, Flash, and Pulsate.
You can find more info here: How does the spotlight on my Arlo camera work?
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
