Can't delete videos anymore
I've had my doorbell camera for a couple months. For a while I had the option to delete videos from my device. I no longer have that option, and I have hundreds of videos on my feed. The only option I can find only allows deleting one video at a time. Can someone explain this to me?
While I recommend never deleting videos since you may want one back (and they will be deleted automatically later), I find that at least on the Android app use of portrait mode gives you a menu (3 dots) that allows you to delete a video.
I know I can delete 1 video at a time. When you have hundreds, that would take forever! I guess my main question is... are these videos stored on my phone? If not, I won't worry about it.
Cloud recordings are always in the cloud unless you happen to download them. Same with local recordings if you have that set up.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
