Usually clicking on the numbered badge for a camera in the Devices card will take you to the library with a filter set so only that camera's videos are displayed. That action should clear the number although I believe iOS users have had this sort of problem for a while now (I'm strictly Android). You can also try the web client to see if that works any differently and/or clear the number.
BTW, Netgear originally owned Arlo but Arlo was spun off as its own unique company. Either way, the camera systems are the same.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
