- English
- Cameras
- Re: Arlo wireless door bell stop detecting motion
My arlo wireless door bell has stopped detecting motion and notify when armed from 2 days, have reset it and ensured the Wi-Fi strength is good. No error status on the app too, still it’s not detecting motion. Tried contacting customer technical support but have been in queue for like hrs now. Does anyone faced similar issue and what did you do to resolve this issue. As the new range has been launched the older versions have degraded in performance? Are we eligible for upgrades to the newer version or any software firmware update is required to the old devices. I also have a subscription plan. So was expecting some technical help, but not able to get through them hence reaching to this community.
Have you tried the motion detection test?
Also, it might be good to make sure you can make a manual recording while livestreaming.
Yes, tried motion detection test too. I can see the indication line on the door bell but it doesn’t record any video or notify of the motion detected.
I can manually record a video when seeing live feed.
Yes, I am.
@Paliwal27 I have escalated this to support and someone will be reaching out to you as soon as possible.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
