Arlo essential XL spotlight cameras
I have 2 arlo essential xl spotlight cameras. Both cameras have lost battery power. Nether one will charge when I plug in. Both cameras are WiFi connected directly to router. The only light that eventually comes on when I plug in are the IR camera small lights. I am using the power cords that came with both cameras. Alternating just to get some response. Reset does nothing. No blue lights. Both cameras are 1st generation. 1 year old. Help. Frustrating
Is it possible to try with another power adapter and cable? It's not likely both cameras have battery issues at the same time.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
