Arlo VMC2030 Essential Spotlight not recording in Arlo Library
  • 6 Replies
  • 2833 Views
22857
I Have 5 Arlo Cameras: 3 Arlo Pro2 installed 3 years ago and in  November 2021  I bought   2 Essential Wire Free Spotlights and I added them to the Base Station VMB4000r3,  I noticed that events from Arlo Essential send motion alerts but they are not recorded in the Library, I have installed local USB WD Storage 1TB , I deleted all old events from Arlo Pro2,  it continues recording only the Pro2 but nothing about the essentials. I reseted and installed them again, I turn off  and on the base station . Help me please. Thanks
6 REPLIES 6
Dannybear
Can you check if the essential camera subscription plan has ended? Pro2 cameras come with free 7days cloud recordings.
22857
Hi, Thank you for your help, let me tell the truth, I bought them -2 Arlo Essential Cameras-  on March  23, 2022, I did not register o subscribe them  in any plan I only installed them  (adding to the Base Station where I have already installed the  Pro 2 cameras) because I had family issue to take care. Now that I need  really  to see what is going with cameras. Like I said before I have USB local Storage where all alerts / Events are recorded, but its no convenient when traveling. Thank you very much .
Dannybear
Yes the 4000 base does not provide app access to the backup USB recordings, only the 4540 and 5000 have that option employed and it is a chore to set them up to remote access away from the wifi, need to keep rebooting the router etc.
If the essential cameras are connected to the base station they should backup recordings to the USB although arlo may have dropped that feature. Make sure you have them connected via the base station.
22857
thank you for your help. Still I have no idea why I can see in the Library the alerts from the Cameras Arlo Pro2 but not from Arlo Essentials Spotlights.???
Dannybear
Just to clarify that the pro2 cameras have free 7days cloud library where as the later model cameras require a subscription plan to enable the feature.
The best you get is notifications and live viewing as well as recording to the base station backup USB.
You should have access to the 12 month or at least the 3 months free trial option to test depending on where you purchased.
https://kb.arlo.com/000062416/Arlo-Essential-Wire-Free-Camera-Series-FAQ
22857
Thank you very much, I bought the cameras from Arlo Store - Online-.  Tuesday I'll  call them about the 3 months free trial that still I'm would have it.
