Arlo Essential with VMS3130
I try to connect my new Essential cameras to my old system Arlo Security System VMS3130 but it dosent work.
Is there an another basstation smarthub I need ?
Not sure what base you have. The Essentials can connect with the VMB4000 or later, but not with the VMB3xxx bases. https://kb.arlo.com/000062284/What-is-the-difference-between-each-Arlo-SmartHub-and-base-station
But if you don't have a compatible base, you could connect the cameras directly to your home wifi.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
