  • 7 Replies
  • 2663 Views
bbaskinfl
I've added Secure AFTER the trial expired.
I've paid for Secure and the subscription has been added to my account.  The system recognizes my two devices.
The plan is shown and states "0 of 2 devices".
Despite searching under FAQ's the instructions for "dragging and dropping" do not correspond with what options are on my screen.  Perhaps the instructions are old.  Yes, I am trying to add the two devices using my.arlo.com.
Can someone provide clear directions for this problem, please.
7 REPLIES 7
DannyBearAgain
bbaskinfl
Thank you for sending the thread.
Yes, this concerns my problem but the thread ended without providing a solution.  It ended with a moderator stating “our development team is working on it”.
And yet…it remains an issue in 2024.  The thread was dated 2022.
When you log into your account, do you see "Feed" and "Dashboard"?  Or do you see "Library"
Also, did you purchase multicamera Arlo Secure?  Or individual camera subscriptions?
The current plans are for unlimited cameras. There's no "drag and drop" since each camera should be automatically added to the plan. Specifically, what plan do you have? Also, which user interface (UI) are you using - the old one that uses Library to view recordings or the new one that uses Feed? The current app supports both UIs so it's not an app issue.
bbaskinfl
I see Feed and Dashboard and several other options on the left side of the screen.
I purchase the option for four devices.
bbaskinfl
On my.arlo.com it opens to feed.
My subscription is for four devices.
Thank you.
Did you purchase the unlimited plan or 4 individual single camera plans? A screenshot of your subscription may help.
