Arlo Essential Solar Alternatives
Hey fellas,
I have a small power issues with my cameras. They are in a location where I can charger them, but taking them down is a pain so I've bought a 25000 power bank to charger the cameras. So I bough the solar panel that was design to charge the Arlo Pro. After trial and error and reading this forum come to find out it will not work. So my question is...is there a alternative solar panels out there? I know the cameras take 9v/1.1a, but is it possible to buy a solar panel that outputs 9Vs and used it? There is no status on the VMA3600 Panel.
thegeneral217,
The vma3600 Solar Panel is available for purchase from the Arlo store. Take a look here: Arlo Essential Solar Panel
Remember, solar panel and/or a power bank will not provide the permanent power you need to enable features that require a mains/USB connection.
Just another user
What happened to the Arlo Essential Solar Panel? How could it not be available already for a camera that JUST came out? Does anyone know if any of the 3rd party solar panels out there will work with the Essential?
You can use any power bank type charger. Suggest 10,000 will provide perhaps another 6-8 weeks.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
