Arlo Essential H8 Camera video pinkish Hue?
Sometimes, not alway my video has a Pinkish Hue. Other times the picture is perfect, Have video one day that is fine, next day at the same time, same person walks by and the video is all pink? I have another exact camera installed at the same time & place, facing a different direction and occasionally it will just be digital static? I'm at a loss. I have both cameras on 110 volt power, set at best quality video and good WiFi signal to them. No rhyme or reason that I can see to this.
Lowell95,
Could you provide a screenshot of the issues you're describing, that may help us better understand exactly what you're seeing.
Sure this pic is from today, I will upload one from yesterday at about the same time
THis was yesterday about the same time of day.
This screen shot is couple days ago, only a couple hours apart.
Lowell95,
Do you ever see this behavior when live streaming the camera? Does it only happen with recordings?
Working OK again today, I suspicion that the activity zones are causing the problem. I deleted the activity zones to see if the problem goes away.
Sorry, to correctly answer your question. It doesn't seem to occur when livestreaming, only with recordings.
We I guess deleting the Activity zones did not effect the camera. Today the hue is back on the screen. It is there on both the recordings and the live camera. It's like every other day thing?
Here is a shot of the live view today. Yesterday was fine, not so much today!
I'm wondering if the nightvision filter is misbehaving (engaged during a daylight recording).
I turned the the Night Vision switch off and so far no change on video image. I already had the floodlight switch off. I will leave the Night vision switch off for a day or so and see if that helps anything.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
