All my cameras are offline and can no longer be connected
  • 1 Reply
  • 3353 Views
  • 1 In Conversation
spadoinkle
Hello everyone
I'm turning to the community because I can't get any further.
I have three Arlo Essential Spotlight cameras. These have worked relatively well so far. Since today, however, I have been experiencing real problems.
The cameras are reporting that they are offline. I have tried to reconnect the cameras several times according to the troubleshooting guide. Without success. Password and network are correct.
So I removed the cameras from the app and tried to reconnect them - that didn't work either. I also completely reset the device afterwards.
Nothing has been changed on the network (for several months). It has always used the same SSID (2.4 and 5 Ghz network). So far, the cameras have never had any problems with it.
I have gone through all the troubleshooting guides. Without success. In desperation, I created a separate 2.4 only network and tried to reconnect the cameras. Also without success.
According to the status page and other down detectors, the Arlo services all seem to be running.
I don't know what to do. Does anyone have any ideas?
spadoinkle
Update:
I found the culprit shortly after my post -.-"
I had stored 4 DNS entries (4 different DN servers) on my router. Apparently the Arlo Essential Spotlight cannot handle 4 entries. As soon as I deleted one, the connection worked again.
Maybe helpful for those who have the same problem in the future 🙂
Solved!
spadoinkle
Update:
Solved!
