All cameras light up at once
I have a mix of essential spotlight ver 1 and 2. Eight cameras in total. Battery consumption is rather high.
The last months, I have observed that all spotlights light up, even if I just want to go in and check one camera.
I would like to have the previous behaviour, where I could go in and check the feed from one camera without turning on the lights of all. The whole property lights up, and that can be disturbing..
@egilso wrote:The last months, I have observed that all spotlights light up, even if I just want to go in and check one camera.
Are you saying that when you livestream a camera and then toggle the spotlight on the livestream page, that all of spotlights turn on? FWIW, I am not seeing that on my system.
How often do you need to charge them?
Hi! Yes, when I go to the app in the evening to watch the feed from one camera, I can see the other cameras wake up and light up the property in all directions. I do not have to turn on the spotlight for the others to light up.
If I do this repeatedly, eventually the other lights will turn off.
The cameras not on solar will go down from 100 to 85 pct in a week.
So about 5 weeks between charges (assuming you won't let the cameras drop below 15%).
Are the cameras recording? Just wondering if you've set them up to cross-trigger.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
