I've been without a hub on my essential spotlights for quite some time without issues. I found a new smarthub on Amazon for less than $50 so I figured I'd give it a shot.
I noticed that after reviewing videos saved in local storage, there are some videos that I never received a notification for and that do not show up under the feed section.
Is this normal?
Activity zones are applied in the cloud - so out-of-zone motion will be saved on the USB drive, but not the cloud.
Do you have activity zones set up for the cameras?
I do
Oh OK, that makes sense.
Thanks!
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
