JP7,
Outdoor AC charging cables are not available for Arlo Essential Spotlight cameras. For outdoor charging, we recommend the Arlo Solar Panel. For more information, take a look here: Arlo Essential Solar Panel
JP7,
One to add here?
Arlo Idea Exchange - Arlo Communities
If Arlo doesn't respond, there is a good chance that one of the third party suppliers will step in. This is such an obvious need.
Just another user
My friend bought a 16ft usb power cable. The rubber/plastic around the connector needed to be trimmed because it was a tight fit. Don't let anyone from the company make you think you need to by the solar panel. Buy the power cord and power it full time and be done with it. Non removable batteries on this model were a terrible design.
Bevor Sie kaufen
Detección de Movimiento
receipts
totally frustrated
VMC2030
VMC2030-100EUS
