Texas
  • 1 Reply
  • 410 Views
Ltlov
First time charging my cameras, how do I charge them if they are on a secure amount? Do they pop off so that I can charge them or do I have to bring a charging cable to them outside? I forgot to ask when they were installed
Do you have this mount?
If so, it is easiest to charge the camera in place.
You can alternatively take it down using the supplied security key:
If you don't have that key, a 2 mm hex wrench will work.
  • 1 Reply
  • 410 Views
