I've had the VMB4540 for years. One of my cameras stopped holding a charge, so I got the Essential 3rd generation because it is compatible with my base hub. I don't have a subscription, I record videos locally to the hub. But I just found that the 3rd Gen won't save locally and will only save with a subscription. Is there a way to get it to save? Or else I'm done with Arlo.
Is the camera paired with your smarthub? Or did you connect it to your home wifi?
