Livestream only works at night
  • 20 Replies
  • 577 Views
RichardTX
Livestream only works at nighttime when the night vision turns on. I can hear audio on the livestream during the daytime, but when i press play it is stuck loading.
RichardTX,
The development team has made some adjustments that should alleviate the issue you're experiencing. Please close and relaunch the Arlo app on your mobile device and then attempt to stream your camera again. Please let me know the results.
Thanks!
20 REPLIES 20
RichWood
Unplug the camera and plug it back it. It's a known issue. I guess it's being worked on. If you connect on a 2.4 GHz band it happens less frequently
RichardTX
Yes i have. Removed, Reset, Reinstall, Put the camera within 6 ft of a router, tried on a different phone, i have done everything. Wifi is at over 800mbps download and 40mbps upload. It will only livestream once the nightvision turns on
RichardTX
This also happens when set to 2.4ghz only. And even when i bring it inside right next to my router.
RichardTX,
Is this only happening on a specific camera or are you experiencing this behavior across multiple cameras?
RichardTX
Multiple cameras. I just verified that if i cover the camera with my hand, it will start live streaming. I have pictures showing this if you would like to see them
Yes, that would be helpful. I have already escalated the details you've provided here. Any additional information we can provide to the dev team will help isolate the issue further.
RichardTX
RichardTX
RichardTX
RichardTX
Thank you for the screenshots.
If possible, please provide app logs, you can collect these by logging in to your Arlo app and navigating to Settings > scroll down to About > tap "Version" several times until you are prompted to share the log file. You can then email to AskArlo@arlo.com subject line attention JamesC Pan Tilt Live Stream Issue
RichardTX
The camera will say connecting and never connect if it is bright outside, but i can hear sound. As soon as it gets dark, or i cover the camera light sensor, the live stream will start working
RichardTX
I will try to get the app logs for you
RichardTX
I just sent the app logs to you
Excellent, I've received them. I will get this information in front of the dev team for further investigation.
Thank you!
RichardTX
I have some more information. Technical support called me back and asked me to check my cameras on a computer, using my.arlo.com. I can livestream during the daytime on the website. So it seems to be an issue with the Android App. I am currently working with them on this issue. It is weird how it only works with night vision on the App.
RIchardTX,
Thanks for the additional information. We're still investigating this issue but I believe we're close to a solution. I will keep this community thread up to date as we learn more.
RichardTX,
Thanks!
RichardTX
It works now! Thank you!
Great! Thank you for the confirmation.
  • 20 Replies
  • 578 Views
