Camera not tilting
  • 636 Views
Timmy_187
My camera don't want to tilt what can I do to fix it
How are you trying to tilt? Is this during live view?
Josh83648
This is an old post but I see no one really gave good answers....2 of 3 of mine just stopped tilting as well. I could hear the motor running trying to move it but it just wouldn't move. I pulled the side case off to find the bracket that the gear shaft slides into shattered into 3 pieces. I suspect the other camera is the exact same way. Cheap built camera that they don't sell parts for.
BrookeN
@Josh83648 Can you please dm me a callback number as well as a good time to call. That way I can have support look into this further. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
  • 637 Views
