I purchased a new Essential camera, and I’m experiencing an issue with videos not displaying on my SD card. All my other cameras show up on the card. I’ve noticed that on the older cameras, when I view the screens in the device area, there is an SD card icon in the lower right corner, along with battery power and Wi-Fi strength icons. These icons don’t appear on the new camera's screen. Any help with this problem will be appreciated. Keith
This problem seems to have fixed itself. I can now see the videos on my SD card.
Is the camera connected to the smarthub, or is it connected to your home wifi?
Is the camera armed?
Since my last post, I have noticed that my videos from the camera are being recorded to the cloud and not to the local SD card. I don't know how to get it to change over. All my other cameras are sending videos to the SD card?
Yes Stephen it is connected to the hub and is armed. Thanks for replying to my message.
Is local storage set up in the smarthub?
If you aren't seeing the recordings when you press "local" in the app, then you should try ejecting the SD card from the app and connecting it directly to your PC. Then look for recordings.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
