Using WiFi extender
  • 382 Views
Orrefors
Anyone used an WiFi extender like
RE705X to connect to the base station to get some more range?
That won't work.  There is no way to pair the extender to the base wifi network.
Orrefors
dont really understand the answer.
No need to pair the extender differently than if the extender was not in the chain.
am i missing something ?
The Base Station will be connected to the LinkSys extender with an ethernet cable.
Link Sys Router
↓ Wi-Fi
LinkSys RE705X
↓ Ethernet
VMB5000 Base station
↓ Arlo wireless connection to
Cameras
Ok, that will work.  It doesn't let you increase the range of the base, but it does let you change the location, so you can get stronger signal at the cameras.
I understood your first post to mean that you wanted to extend the base station wifi network.  Which can't be done.
