Tips and tricks for charging 2nd gen Essential
We have a lot of Essential cameras and unfortunately solar is not good enough to charge them with the limited sun we get. One thing I have found is it can be really tricky to get the cameras to charge via USB, too! Some of the units are very picky about the power source or USB cable, even though they're all the same hardware revision.
One thing I have realized is it takes some time for the cameras to realize they are not plugged into a solar panel anymore. If you immediately swap from a solar panel to a power bank or similar, it will draw 2W maximum (usually just 1W, doesn't show up as charging in the app). I've found that you must unplug the solar panel and wait a few minutes. After that, it should draw almost 9W (depending on charge level -- it'll taper off as it fills).
I was curious if other people had any quirks they've found with theirs.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
