Stops Recording everday
  • 6 Replies
  • 1179 Views
Boonty1000
My cam needs to be restarted every day otherwise it stops recording.  Once restarted it will record for a anywhere between a few hours and and a day before it needs a restart again.  I can always connect, but when I view the dashboard that camera has stopped producing files.  It's the only camera that does this, I have 6 but it's also the only camera that is permanent mains power.  The others are via solar.  Any ideas?
6 REPLIES 6
What happens if you disconnect the power as a test?
Retired_Member
Not applicable
Same exact thing has been happening to me. plus my CVR footage is not recording as well. I have to keep restarting this thing even after restarting it my CVR does not work. What am I paying for
Boonty1000
im running on battery now and will see.
Boonty1000
SO my theory is that it is being throttled by Arlo.  Its the bussiest camera in my set, often picking up 100+ movments in a day.   The other camera that pick up far less movment never have this issue.  Ive got a few other test to run first.
Boonty1000
Mine does record for 10 - 12 hours before it stops.  I can still connect and manually record but thats it.  For you, try arming then disarming the camera.  That worked for me once before.
Maybe try swapping the camera with another one, and see if the problem moves with the camera (or not).
