New to Arlo and not knowing until you know, I wonder if my model camera essential Outdoor 2nd generation, is supposed to actually swivel/rotate, or is the positioning, once mounted, determined by going in to the app and adjusting the camera angle from there? My camera and Mount is fixed and unable to be manually rotated. Also, how easy is it to detach from wall for recharging?
Dlauren,
While the mount will be relatively stiff, once the camera is secured you can swivel/rotate the camera to the desired position by applying some force. To remove the camera for charging, you can push up on the mount to release it from the wall mount bracket.
For more information on this, see here: https://kb.arlo.com/000063167/How-do-I-mount-my-Arlo-Essential-Outdoor-Camera-to-a-wall-2nd-Generati...
Dlauren,
Many thanks, and much appreciated
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
