How do I remove the camera to charge the battery? It looks like it has a ball swivel and I don’t want to break that while getting out. Don’t want to remove whole mount either
Parker77,
To charge the camera, remove it by sliding it up off the mounting plate. For more information, see here: https://kb.arlo.com/000063167/How-do-I-mount-my-Arlo-Essential-Outdoor-Camera-to-a-wall-2nd-Generati...
Parker77,
After placing the the camera onto the wall plate and sliding down to lock, there is no way to remove the camera for charging, as there is no way to unlock from the wall plate.
bukhrn,
While it may be difficult to remove, you can slide the mount up and remove it from the wall plate.
You can only remove the camera if you've removed the locking tab prior to installation. We have three Essential XL's and three Essential's and in all six the locking tab has broken after many removals for charging. The best thing would be to just break off the locking tab prior to installation. Then you can easily slide the camera up and off of the mounting plate...it's going to break anyway after four or five forced removals. It's a horrible design, with the camera screw inside the mount and the locking pin under the mounting plate. They should have put a small hole in the bottom of the mounting plate so you could stick an open paper clip or something in there to unlock it.
Well that link was no help. The question was how to remove the camera from the mount not how to mount the camera
There are three relevant parts, not two. There is the camera, the mount, and the wall plate. For charging, you remove the camera+mount from the wall plate - you don't need to detach the camera from the mount. To do that, you
- Look carefully at the mount, and locate the triangle (arrow) embossed on the edge. If you followed the mounting instructions in the link above, that arrow is pointing up.
- Slide the camera+mount in the direction of the arrow.
It can be hard to slide, but it should come off the wall plate.
If that doesn't work for you, try rotating the camera, which will unscrew the camera from the mount. Then it will be easier to slide the mount off the wallplate. But you will have to re-attach the mount to the camera before you can put the camera back.
What if I accidentally locked the camera to the mount before installing the mount to the wall. Any way to get the camera off the mount?
I don't know any way to do that with the Gen 2 camera.
But if you can't slide the camera+mount off the mounting plate for some reason, you can alternatively unscrew the camera from the mount by twisting it. Then lift the mount from the plate.
Then attach the camera to the mount before putting it back onto the plate.
If you have access to the back of the mount, that shall face the wall, simply push the small locking tab and then you can slide the plate.
If it is mounted on the wall you cannot access the lock tab and have to slide it using brute force until the locking tab folds.
It is an incredibly stupid design to have a locking tab tab that is not accessible after mounting.
Before mounting (again or from the beginning) do remove the lock tab!
All I need to do is locate the arrow embossed on the front of the mount, and then slide the camera in that direction. No need to push anything on the back.
If that is hard to see, then simply unscrewing the camera will remove it from the mount, and then you can easily slide the mount off the plate.
What dope designed a mount that you can't remove the camera from to charge it?
Like seriously ARLO, who's this stupid?
You certainly can remove the Gen 2 cameras from the mount - look at my post earlier in the thread.
Having to intentionally break the mount in one specific spot before you put it on the wall is a terrible design. Doubly so when absolutely nothing is mentioned about removing the locking tab in the instructions.
You didn't have to break anything and you didn't need to remove the locking tab. All you had to do was locate the triangle embossed on the mount base, and slide the camera in that direction.
Your other option would have been to just unscrew the camera - then it is easy to see how to disconnect the mount from the base.
I have removed my own camera from the mount several times, and my locking tab is still intact.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
