- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Recently had to get new phone, when I try to logi...
Recently had to get new phone, when I try to login it says don't recognize device
Recently had to get new phone, when I try to login it says don't recognize device, also says sent a push notification...where do they send push notification ?
Assuming you have a new phone number, the push would go to the old one. If it's the same number, be sure you check the phone's settings for the app about notifications.
You should also see a link below the 2FA prompt to use a different method. Click on that and choose email.
No same phone number, when I had to replace last time was easy and logged almost instantly but was same model s22, upgraded to s24 now and it don't recognize
Did you try using the email alternative?
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
