- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Motion sensor stuck on after a few notification
Been having this issue for several weeks now, even got sent a replacement camera that does the same thing. Camera will have motion detection, send a few notification and then the motion sensor icon will get stuck on indefinitely, and live view stops working, the wheel will just turn and turn. Only way to stop this is to remove the device and re add it again, to which the issue happens all over again, few notification and saved videos and back to being stuck on.
Spoke with a agent and they said the camera needs 2mbps of upload speed even though I have a 15mbps of upload speed and only two other devices connected to the network.
Not sure it will help but what happens if you change locations for the camera or even bring it indoors for testing?
Contact support! I'm having the same issues and was told that the engineers are working on a firmware update.
The more people that complain the fast the fix!!!
No change in moving to different location.
I spent 3 hours with support troubleshooting, nothing helped. Support then sent me a new camera that’s doing the same thing as the last one.
Ask support to push it up to engineering. That way you'll be added to the list of people complaining and hopefully that will speed up the "fix"
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
