Font size too big
  • 1 Reply
  • 1059 Views
Don397
FYI for anyone having the same issue connecting the Essentials 2 2K that I had. Tried everything from previous posts I read. Wouldn't let me connect via 2.4ghz selection. Turns out after speaking to support,  my font size on my android was too large. So shrink the font to a small size and problem solved. Hope this helps out.
Sounds like something Arlo should fix.  People with impaired vision need those larger font sizes.
@JamesC:  Is this in Arlo's bug database?
