My camera with only 3 months use is not recording any motion.
You can see live feed well just no motion pick up for recording.
Has anyone experienced this before?
Did the trial subscription expire?
The camera was bought in April 2024 and not installed until June 2024. So I don't know how Arlo would view the subscription trial period. However, we have been using Arlo for a few years with a monthly Subscription which is still ongoing so it we are definitely covered.
Out of the three Essential XL 2nd Gen cameras bought at the same time. 2 are now faulty and this one does not record motion.
So wondering what I can try to fix it. Arlo customer service is open tomorrow so I will also raise a ticket with them on this topic unless the community has any ideas.
The trial subscription starts with you install the camera.
While it is supposed to move automatically to your paid subscription when the trial expires, it is worth taking a look.
Also, I suggest
- confirming that you can make a manual recording while livestreaming the camera
- checking the rule for the camera in the mode you are using
- temporarily removing any activity zones
- temporarily turning off smart notifications.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
