- 2
Hi, I can't find 2nd gen model for Essential Outdoor camera when I started setup (updated latest apps version). Understand that it's not released yet in Hong Kong for this model, hence it's the reason why I can't search it in apps.
1) Could you let me know the schedule when it will release and support in Hong Kong?
2) Any alternative way to pair it? For example, register a supported countries account and pair it (PS: I registered a US arlo account, and switched location as US, but still can't see this 2nd gen model in the list, any advise?)
We need a date when will this issue be fixed????
We paid alot of money for useless cameras!!!
Is it in the plan to roll out to other regions???
I do not have an ETA on when Arlo Essential 2nd generation products will be available for onboarding in all regions. Once I have more information to share, I will make an announcement here.
Please treat this with importance as many people paid alot of money buying your products and it is useless till now.
We want to know if you are working on it with no expected ETA or you are still not decided if you will open them in all regions or not
@JamesC We keep received this shxt reply many times! Enough!!!! We need a plan, Come on!!!
I am in the same situation. Essential 2nd gen outdoor is not in the app list yet. Waiting your news when it will be available??
I live outside the US and I am now able to add 2nd gen cameras to my Arlo Secure account. My account was created in the US.
To note about the latest software, though you have iOS app ver 4.11.1, you have to update the software internally. You can do so by going to add a new device > cameras > pro series > pro5s and do an internal software update to get the latest interface on iOS ver 4.11.1.
Up until yesterday, January 22nd, I was only able to see 1st Gen Essential cameras. As of this morning, January 23rd, I am able to add 2nd Gen Essential cameras.
Hope this helps!
Arlo Essential Outdoor 2nd Gen Arlo Essential Indoor 2nd Gen
It was too good to be true. It was there and then it wasn’t. Arlo Support didn’t even have an answer for me. Hope it becomes available soon. Any updates from Jamesc ??
Hello,
I have solved the problem of not having the camera at the app list by creating an account at USA and reaching this account from my origin country. I have uninstalled the app and installed again and logged in with the new US created account. Then had the Essentials Outdoor 2nd Gen at the list of cameras. Initialized them with the App and they are working. Need to make the physical installation.
Hope this can help the others who has the same issue.
Another update to the 2nd Gen Saga…I was able to add my 2nd Gen cameras on an Android device vs my iPhone. Not sure how to explain this, but that was the only way. Again, I live outside the US and have a US created account, but did not have the option to add 2nd Gen Essential cameras on my iOS device. Signed into my account on an android device and there it was.
- Is the iPhone set up to use the US account credentials, or is it set up as a friend account?
- Did you have a VPN running on the iPhone when you tried to add the device?
Exactly the same for me . I am a long term ARLO user and customer . I just got 2 x Arlo Essential 2nd generation and not able to pair with Hug or any other way.
I got it from Best Buy 2024/01/17 .... and never knew can not be used outside US , otherwise would get Pro4 or Pro5 ... Outside the packing must be labeled ! ...ONLY FOR US MARKET !!! Please update asap Help your customers ...otherwise it is not good.
My Arlo account was set up using a VPN and is a US region account.
When I added the 2nd gen cameras, I used an Android device WITHOUT a VPN and was successful. The option to add 2nd gen Essential cameras was not available on my iOS device even with the latest software update and user interface.
No VPN was used when I tried to add the 2nd gen cameras on my iPhone. With or without a VPN, I did not have the option to add the cameras on my iPhone.
Enabling the VPN at during onboarding will generally result in the onboarding failing. So keeping the VPN off was the correct thing to do.
Which is right process. Was the iPhone connected to your home wifi network? Was BlueTooth turned on?
Hello @JamesC any update about this problem? I set up my Arlo account in Hawaii and now I'm in Chile. I can't add second-generation products from the app. I'm using the latest version of iOS.
I had the same issue trying yo setup Arlo 2nd generation cameras from Egypt
I solved the problem by
1- Making a friend creating a new acount while in USA
2- He sent me the credentials
3- open the arlo app using the new account
4- setp up the cameras from Egypt
I live in Panama but bought the 2nd generation Arlo Essential while in the USA earlier this year. I’m unable to onboard them to my existing system. The app does not show the option. When will the 2 generation be available in Panama or what do you suggest I do to get the installed.
I really don't understand how they can treat customers so badly. I bought my cameras through Amazon, I'm from Chile and nowhere did it say that they would only work in the USA. I feel cheated. If it is as simple as enabling the application for everyone.
I had the same issue...
If you know someone who lives in USA tell them to create an account from USA then continue your normal setup jn Chile using this account.
It worked for me
I purchased 2 essential XL outdoor cams. It turns out, that there is no security plan support for Liechtenstein. This is hardly published on the Arlo web site. Also, it's called the WORLD wide Web.... so why exclude Liechtenstein? It's not Russia nor North Corea.
I'll return the devices and look for another supplier.
The Arlo web site however fails to draw attention to the facts that a) one needs to purchase a support plan to record still pictures and video and b) that such plans are not available in all countries. Sucks.
I bought Arlo Outdoor 2nd generation cameras while I was in the USA, and now I live in Egypt. When I try to pair them, I cannot find the 2nd generation option. Is there a way to pair them? The only option is 1st generation.
I had the same issue i got it from usa and couldn't pair them in Egypt.
You have to create your arlo account while in USA first.
If you know someone there make them create the account there... Then you will be able to set up the 2nd generation.
- 2
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
