Essential 2nd Generation devices are now compatible with Base Stations and SmartHubs
  • 2 Replies
  • 1973 Views
raywst
Hi
What are the advantages connecting the  Essential 2nd Generation devices to the Base Stations/SmartHubs.
My Essential 2nd Generation is currently connected to the WiFi. However, when I tried connecting to the Base Station, it failed. Do I need to reconnect the Essential 2nd Generation from scratch?
raywst
Thanks. I found there is delay when loading from the hub once the Essential 2nd Generation is connected it.
The loading from the WiFi is instantly.
At the moment the only benefit is local storage.
Yes - removing the camera from the account, and adding it back.  You also need the firmware updates.  See post 15 here:
raywst
