Device order in feed
I was able to change the device order in my feed in the old app but cannot find it in upgraded app. How can I change device order in upgraded app?
Tap the three dots in the top right hand corner of the app while on the devices tab, from there you can press and hold on the device widget you would like to move, this allows you to drag it to the desired location.
Additionally, you can customize the dashboard as you see fit with larger or smaller camera widgets. For more information on dashboard, see here: https://kb.arlo.com/000062915/What-is-the-Dashboard-on-my-Arlo-Secure-App-and-how-does-it-work
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
