Hi All,
Just bought the Arlo 2nd Gen and Chime, got the doorbell working,but the chime will not connect at all. I've tried another device too see if that will sort it and it fails to connect.
Can anyone help before I end up taking it back and get a different product?
WHich chime? There have been 2 similar but different ones.
WHat do you mean by trying a second device? A different phone or did you swap the first chime for another? Are you using iOS or Android? What exactly have you tried and what do you see? The whole sequence of events is needed.
Hi,
Chime 2 which came as a freebie with the doorbell from Argos.
Tried a different phone, Android.. I've reset the app, reset the chime several times as instructions have said, it gets to connecting then fails to connect to Arlo_4811 everytime. the doorbell has connected first time.
Check that the phone settings allow unknown open WiFi connections to occur. If that doesn't help, I'd swap it at the store.
Hi, @ShayneS
Gave up in the end as it was on the 2nd chime 2 and took it back to retailer as faulty goods, got another brand instead and it connected 1st time with no issues. Doorbell worked perfectly, just the chime that wasn't wanting to play ball.
Maybe there's a disconnect here. You make it sound like you used a normal/traditional chime rather than an Arlo one. Replacing with a different brand isn't possible if we're talking about the Arlo chime.
I've taken the entire doorbell and chime back as the chime 2 wasn't connecting even the replacement wasn't. So I had got fed up, bought another brand doorbell and chime to replace it and they both connected to my WiFi first time
Thank you for the update.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
