Charging icons
  • 5 Replies
  • 2493 Views
JoeFavs
Newly installed gen 2 essential 2k camera installed. It’s hardwired and upon install the app icon showed green and charging.. it’s 100% charged  now,  the icon is no longer green but now grey.. and it does not have a lightning bolt showing charging.  I’m confused because my 1st gen hardwired cameras always have a green icon regardless of charge leve
any thoughts would be appreciated
JoeFavs,
If you have a solar panel or charging cable attached to the camera, that should keep the battery level topped off. If the battery is already at 100% charge, the battery indicator will not showing charging until they battery depletes and needs to resume charging.
5 REPLIES 5
JoeFavs
Will a wired gen2 essential 2k camera stop charging to prolong battery use like the video doorbell
initially the green charging icon was illuminated but not its not
amy Insight would be greatly appreciated
What device are you viewing on ... Apple or Android ?
Have you also checked on the web access ?    my.arlo.com
JoeFavs
I’m using  the apple app.. the gen 1 cameras have a green icon that remains on .. curious why gen 2 does not indicate the same.. wondering if it’s a battery saving thing..
JoeFavs,
JoeFavs
Thank you community
