Can't change Essentials Camera Sensitivity
I use the current app to reduce the camera sensitivity of my essentials Gen 2 camera from 80% to 60%. The next time I open the app, the sensitivity is back to 80%.
By any chance did you use the Add an Action, Customize Device setting in the camera's rule in any mode? That changes what's set in Default Mode Settings in the camera settings although I wouldn't think there would be any such interaction between the two settings.
You may want to remove the camera from your account and add it back to see if that makes a difference.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
