Just unpacked my first essential 2nd generation camera and took one look at the supplied mount. By the look of it made the mount more secure BUT now there appears to be no method of adjusting the direction of the camera, making the mount almost useless. Thoughts please.
Arlo Essential Spotlight
Athough it is stiff, you can adjust the camera direction. It does take some force though.
Yes, that does work but there is a futher related problem. Cannot remove the camera for replacement or recharging so mounting the camera is a one shot! Reverting to generic mount. No choice
Again, not the case. If you look at the base, you'll see a triangle embossed on it. When you slide the camera+mount in the direction of the triangle, it will detach from the wall. (FYI, it's best to install the mount so the triangle is pointed upwards).
The other option for removal is to rotate the camera, which unscrews it from the mount. Then it is easily detached from the wall. If you remove it this way, you do need a screwdriver to re-attach the camera.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
