- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Arlo Outdoor 2nd Gen won’t connect @ initial insta...
Arlo Outdoor 2nd Gen won’t connect @ initial install
Just bought a set of 3 outdoor cameras and tried to set-up, but kept getting Error 12800 and Error 4103. Here is what I tried so far:
- Went into my router settings and set it from automatic to 2.4ghz.
- Factory reset all cameras (even though they are fresh out of the box).
- Power cycled my router.
- Factory reset my router set it all back up again (2.4ghz of course).
- Unplugged everything and gave up.
Same error codes each time when setting up with all three cameras. First it says Error 12800, tells me to check connection, make sure password is correct, etc etc, and to Try Again. Well, I click Try Again while I am a foot away from the router and then it says Error 4103. Rinse and repeat. Someone help before I return these.
Unfortunately, we don't have access to what those codes mean. However, the change from one error to another when the camera is a foot away from the router may be due to signal strength being too high (too close). Try to keep them, say, 6-10 feet away.
What encryption is being used for your WiFi? Have you tried a different one? Arlo expects to use WPA2 (AES) but WPA3 settings may be useful, depending on how the manufacturer provided it with backwards compatibility with WPA2. Any other security settings you may have changed?
Also, your phone needs to be connected to your home wifi. If you use a VPN on the phone, disable it during the install.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
