I ordered the 3pack of the Arlo outdoor camera 2nd Gen a few months back and they have been working fine. I had no problem charging them until a week ago I charged the one for our driveway and it worked fine through the day until about 930pm and then it kept saying motion detected and it kept showing that until the camera finally died. The next day I turned the camera off and charged again and reset it and when I mounted it back it kept saying motion detected constantly until again the battery died. When I went and looked back at the recordings there was not any motion to set the camera off for motion. Is there something I can do to fix this?
You could try a hardware reset. Remove it from the account, and then use the "pairing button" method here:
ChristieR1021,
Are you using activity zones on this camera?
