  • 37 Replies
  • 12386 Views
  • 3 Likes
  • 11 In Conversation
kb9hgi
I have a 2nd Generation Essential Camera and a VMB 4000 base station. My firmware has been updated so the camera will work on my base station but guess what? It still does not work. When I go into the app and choose Hub/Base station it finds my VMB4000 but will not connect the camera. It says Camera failed to connect and it sitting right here in sync mode. Also tells me Error Code 65535. Now if I try to connect it to wifi it will find it easy and work. I want it connected to my base station!
Best answers
  • BrookeN
    Can I have you please do a hardware reset. Press and hold the sync button on top of the camera for about 15 seconds or until the LED flashes amber three times and then let go of the reset. Wait for about 1 minute to complete the reset. Once that is completed try onboarding the camera again. Please make sure you are picking the Essential 2nd Gen and follow the set-up flow. Also, make sure your phone is connected to the local wifi network. Make sure the VPN and LTE are turned off.  The reset being done correctly is important so please make sure to do that correctly.
37 REPLIES 37
@Brewster65 wrote:
Spent about 2 hours with technical support to find out the firmware for the VMB400 smart hub is not compatible with the Essential XL Outdoor cameras, even though the Arlo website indicates they are compatible.
Support said I would either need to buy a plan or wait for the firmware update for the cameras and smart hub.
The VMB4000 is NOT a smarthub, and you will not be able to see videos in the app if you connect the XL camera to it.  Only the VMB4540 and VMB5000 hubs have the "direct access to local storage" feature.
That said, it can take a long time for the firmware to roll out to all devices.  @BrookeN , @JamesC , @ShayneS - it is possible to schedule a push of the needed firmware to OP's cameras?
Brewster65
thanks StevenB for the info.
Seems the only difference between the VMB4540 and VMB5000 hubs are usb vs SD card for local storage.  Any other differences that you know of?
And if I install either VMB4540 or VMB5000 hubs I can connect my pro and essential XL cameras for local storage AND view the recorded videos on my app?
The VMB5000 is dual band ( 2.4 ghz / 5 ghz).  The VMB4540 is 2.4 ghz only.
IMO not a very important feature, since 2.4 ghz has a longer range than 5 ghz.
Yes, with limitations:
  • Recordings can only be seen in the app (not the web browser)
  • Recordings can only be seen from the primary account (not "friend" accounts).
  • No thumbnails - everything needs to be downloaded to your phone before you can see anything
  • No ability to take snapshots or manual recordings
  • remote access requires router setting changes that many find difficult (and which don't work with some internet service providers).
TJDR
That's a disappointing list of key functions not available. I do hope it's a case of not being available yet, versus not being available ever, as otherwise it's not making a whole lot of sense to me as to why Arlo bothered to deliver hub connectivity support in the first place.
If the real strategy here is to sell subscriptions then it all makes more sense, but with Arlo's current sub pricing models and strategies, I regret more customers will be looking elsewhere. and not for the reasons people typically think.
These limitations have been in place since 2018.  Personally I think that is a mistake on their part.
Their business strategy is certainly centered on subscriptions.  IMO the focus on the Essential line over the past couple of years is part of that strategy - offering much less expensive hardware than the Pro and Ultra cameras.
Despite the limitations, quite a few people posting here do use local storage w/o a subscription.
chowmowan
I bought 5 2nd Gen Indoor/Outdoor/XL Outdoor Cameras since 06/2024 and bought VMB4540 base station in 08/2024. I am so silly, didn't notice that the VMB4540 base station is not compatible with those cameras. Then wait Arlo released an update for the new compatibility list in October.
But same problem onward as there have nothing recording can be either recorded or stored on local storage. All the devices are installed latest firmware. No improve, no progress on mine!
Is the camera connected to the smarthub?  Or it is still connected to your home wifi?
Have you
  1. gone to the devices page
  2. pressed the smarthub tile
  3. selected storage settings
kb9hgi
Mine will not connect to the base station. It still only connects to the wifi. Someone was suppose to have put a ticket in on this and have not heard anything back
chowmowan
Excellent Thanks! I will follow your advise and try again.
Elbori
I have tried most if not all. And my essential xl 2nd gen still no feed to view. Most  People who buy this system have a basic if not pretty good understanding.  It's not rocket science, it shouldn't be so difficult to setup. Ohhh, excuse me, I got a ping that motion detected, but no feed! Stop asking people do redundant things that don't work!
Elbori,
2nd generation devices require an Active Arlo subscription plan to save content to feeds. Do you have an active subscription?
kb9hgi
This damn camera is still not connecting to my base station. I have done firmware updates and I have reset the camera like was said and yes they are all on the same wifi and no vpn on.  I just started a Blink system and no problems. Think I will replace all my Arlo with Blink. Tired messing with this for 2 years
BrookeN
Were you able to get the Essential to connect from the original post in November? Are you choosing the correct Essential when onboarding within the app?
