Question in Arlo Essential Camera continuous recording
  • 1 Reply
  • 1545 Views
chipge
I just purchased THREE Arlo Essential cameras.
I want to have continuous recording with the ability to look at previous days recordings.
Can I achieve this at all with these cameras?
Additionally, I want to get two more cameras. So, is there a device that I can get that would be local storage instead of cloud subscription for recordings? Also, with the two new cameras I want to stick with wireless and the battery power cordless type (option of plugging in power)
Streak2
Master Master
Do you need CVR or do you just need the ability to view yesterday's recordings?
When you buy your new cameras get ones that come with a base.
You will then be able to have local storage as well.
Your existing essential cameras will be compatible with the base should you want some of them connected to the base instead of via wifi.
  • 1 Reply
  • 1546 Views
