Arlo Essential same power connector as Q?
  • 1 Reply
  • 679 Views
adrock0211
I currently have the Arlo Q camera and unfortunately, it has a hardware issue that is unrecoverable so I have to replace it. I can still purchase the Arlo Q online but I notice it's not really sold by Arlo anymore so I was thinking about upgrading this camera to the Essential Indoor model.
However, I have already run the power cables in my wall and don't want to have to re-run them...which brings me to my question.
Can anyone check and tell me if the power cable connection on the Essential Indoor is the same as the Q and Q Plus? That way, I can just use the same power cable.
Thanks, in advance.
They're essentially the same although it's possible that the plastic surrounds are a bit different so some trimming may be needed. Otherwise it should be fine.
  • 1 Reply
  • 680 Views
