Arlo Essential 93108141673
  • 1 Reply
  • 1383 Views
tvernier
I just purchased and set up my arlo security camera. Everything was fine setting up no problems however when I went to check the feed and test them there is a static sound on all three of the cameras. No matter where I place them the static sound is constant and you can hear nothing else. I've adjusted the volume and turned off and on microphone and speaker. I've unintalled one and reinstalled it to see if that would help and also restarted it.
tvernier,
Are you using an iOS or Android device when you experience this issue? If you use the web client from a PC, do you still experience the same behavior?
  • 1 Reply
  • 1384 Views
