Pre sales question
I am looking to purchase two GEN2 Indoor Arlo cameras. I do not need many features and wondering if a subscription will be required for two cameras. I DO NOT need 30 days of revolving recording and good just with a few days (whatever the mininum is if there is one). I am trying to keep cost down for my 91 year mother, hence, do not want/need a subscription for 30 days.
What are my options if any with Arlo to have cameras without a subscription?
Thank you
RAcosta
Best answers
Without a sub, the cameras would need to be connected to a hub with local recordings configured. You can then use the app to see the recordings but it's not the same as cloud recordings. initially you only see blank thumbnails which aren't filled in until you download the video, one by one.
Otherwise, a couple of single camera plans would be needed.
Arlo Cameras
audio
battery
Cable
Cord
Essential Indoor 2nd Gen
Failed
Indoor camera recordings
New features
not working
notification
Plug
reset
resetting
Stand
support phone
user manual
Vmb5000
vmc3060
Wall Mount
Wifi connection
