Night vision stopped working
Hi,
on my essential indoor camera (VMC3060Aer1.4) night vision stopped working a few weeks ago. The camera emits a constant clicking sound and the video toggles between night vision on and off. There is nothing close to camera that could cause any reflections. The camera has worked without issues in that spot with night vision for months.
Any ideas how can I can fix it?
Kind regards, Mario
PS: Is there any way to file a support ticket if you don't have a subscription?
Are you still experiencing this symptom?
May I ask which troubleshooting steps you have tried so far? I don't want to suggest anything you have previously performed.
Yes, the problem is still there. I power cycled the camera and the issue persisted. For now I disabled night vision to prevent the clicking noise.
I have escalated your case & someone from support will be reaching out to you as soon as possible.
Arlo Cameras
audio
battery
Cable
Cord
Essential Indoor 2nd Gen
Failed
Indoor camera recordings
New features
not working
notification
Plug
reset
resetting
Stand
support phone
user manual
Vmb5000
vmc3060
Wall Mount
Wifi connection
