I'm trying to connect my Arlo essential indoor 2nd generation via hub and Wi-Fi without good results. In my app the 2nd generation cameras do not even appear. I am from Ecuador and have been using the cameras only for live feed no subscription without a problem.
Product roll-outs may not have reached your region yet. In addition, only select countries are allowed to purchase a subscription which is required for cloud recordings. Ecuador is not on the list.
https://kb.arlo.com/000062249/Where-is-Arlo-Secure-available
You have 2 choices:
1) Travel to a country that can get a subscription and create your account there. You should then be able to set up the cameras. You'll need a credit card from that country to purchase a plan. Turn everything off and return home - the system should work as if nothing changed.
2) Use a VPN to a country that can get a subscription to do the same thing. Once the system is set up, you don't need the VPN.
You have 2 choices:
Arlo Cameras
audio
battery
Cable
Cord
Essential Indoor 2nd Gen
Failed
Indoor camera recordings
New features
not working
notification
Plug
reset
resetting
Stand
support phone
user manual
Vmb5000
vmc3060
Wall Mount
Wifi connection
