- English
- Cameras
- Arlo Essential Indoor 2nd Gen
- Can Essential2 cameras turn off when they detect m...
My old Nest camera (pre-Google) could turn on and off based on the location of my cell phone (home or away).
That was a VERY nice function option. I see a post 3 years ago that Arlo does not have that function. Does anyone know if that is in the pipeline for a future update?
Arlo Cameras
New features
It's called geofencing. You now find it under Routines, Automations, Arrive/Leave.
https://kb.arlo.com/000062777/About-Arlo-Routines-Modes-Rules-and-Automations
https://kb.arlo.com/000062942/How-do-I-add-a-Schedule-Automation-to-my-Arlo-system
Awesome. Thx.
Trouble with setup for automation...
When I choose Routines > Automations > '+' > Add Arrive/Leave > choose a geofencing radius (and save) > Specific People Leave (my phone) and save > Then: Add an Action > Change Mode - Arm Away and save > Test Automation (checked)... SAVE IS NOT AVAILABLE.
What did I miss?
A screenshot of your automation may help. I suspect you didn't name it - click on where is says Name at the top.
Thanks, you were right. I did not name the automation :-).
It appears I need to set a routine (turn camera on) for when I'm away and a second routine to set the camera on Standby when I return inside the geofence. Is that correct?
Yup. Arrive and Leave are separate events so need separate automations.
Arlo Cameras
audio
battery
Cable
Cord
Failed
Indoor camera recordings
New features
not working
notification
Plug
reset
resetting
Stand
support phone
user manual
Vmb5000
vmc3060
Wall Mount
Wifi connection
