Is there an update to the android app expected anytime soon to work with 2nd gen cameras? My samsung galaxy S9+ can't interact at all with our new Arlo Essential Indoor 2nd Gen cameras we got last week. My fiancée has an iPhone and she can see everything, although she needed to do the most recent app update. That makes me think I need to update my android app but there's nothing showing for available updates. Is this forthcoming? Is there a date known
Kchaba,
Yes, the newly added cameras will also need to be shared as they are not shared automatically.
On the primary users account, navigate to Settings > People > select the shared user > select which cameras you want to share > Save
It may depend on where you are - likely not all regions have rolled out the new cameras. My Android app shows the new cameras as available to install - choose Cameras, Essential Series and the top choice is for the 2nd Gen cameras.
This is with the 2.8_28588 app.
Kchaba,
When you say your galaxy S9 can't interact with the cameras, what do you mean? Are the cameras being shared to you from your partners account?
Thanks for the reply. Do they have to share each camera individually? We have one older camera and I can see that just fine, I just can't see two new ones we just added.
Kchaba,
That worked, thank you!
Arlo Cameras
audio
battery
Cable
Cord
Failed
Indoor camera recordings
New features
not working
notification
Plug
reset
resetting
Stand
support phone
user manual
Vmb5000
vmc3060
Wall Mount
Wifi connection
