- English
- Arlo Forum Discussions
- Arlo Essential Camera Series
- Why does my Essential spotlight loses connectivity...
Why does my Essential spotlight loses connectivity to base station
- Email to a Friend
- Email to a Friend
Does it record while away?
- Email to a Friend
I actually contacted Arlo Tech Support yesterday and they think that I had too many cameras connected to the Base Station. I had six rather than the five maximum. I removed one and then also did a factory reset on the Essential Spotlight camera. I reinstalled it like a new camera and it’s working again. I will check it while it’s in Away mode later. That’s when I usually have the connection problem. Keeping my fingers crossed!
- Email to a Friend
My two Arlo Essential Spotlight Cameras loses connectivity randomly and frequently since I have installed them. I thought the issue with my first one was resolved so I purchased a second one. I’m really regretting replacing my Arlo Pro 2 cameras with these. I liked the color night vision but not at the expense of unreliability. I fear that when my Essentials are offline, someone will commit a crime on my property and it won’t be captured on video. I feel the Essential Spotlight Cameras are a product failure and hope the there is a fix for them.
Just to be clear… Only my two Arlo Essential Spotlight Cameras have this connectivity failures not my Pro and Pro 2 cameras. They are all connected to the same base station and in the same environment. I have contacted customer support but they fail to understand this.
- Email to a Friend
1scorpion,
What does the signal strength icon show for the essential cameras? How far from your base station/router are they?
- Email to a Friend
- Email to a Friend
Then this morning both my Essential Spotlight Cameras froze up again and then one by one, they went offline. Again I was deeply frustrated. I stared at my camera and started to look around then I noticed that my neighbors on both sides of me also have Arlo cameras.
Is it possible that I have a WiFi conflict with one or both of them?
- Email to a Friend
Interference is certainly possible. The distance away from each system counts, of course. How are your neighbors' cameras connected - WiFi or to a hub? Use a WiFi analyzer app on your phone to find what channels are being used for all nearby routers/systems - that may provide a clue. You can try changing the router channel (which affects nearby Arlo base stations) or move the base away from your router to see how that affects anything.
- Email to a Friend
jguerdat, thanks for your response! Could you recommend a good WiFi Analyzer for iOS that can provide what channels are in use. I have tried "Fing" and Network Analyzer (by Techet). Neither one displays channel usage.
Currently my base station is about 6' from my router. Could being that close cause interference?
- Email to a Friend
