Subscription just for cloud storage use??
  • 1 Reply
  • 829 Views
KIRKJR
After the 30 day trial is up will the cameras still save recordings and work like normal? Is the subscription just for cloud storage use??
For all intents and purposes, the sub is for cloud recordings (not strictly true since you get other features such as Smart). However, the camera will still work fine but the best way to use it without a sub is to connect to a base or hub since then you get local recordings which can be viewed using the app. If connected to your WiFi, the local recordings can't happen so a sub would be needed.
