Hello, when I go into live mode at night, the spotlight will automatically come on. The spotlight icon is off but the led spotlight is on? I don't want spotlight on and it's off in the camera low light settings. When I actually turn on spotlight the night footage is in color and when I turn it off it's in black and white night vision even though the spotlight is still on..... The spotlight will turn off when I exit from live mode.
Funny thing, it turned out that the spotlight wasn't turning on at all. I was looking at live footage from one camera while other camera was live also. The effect was seeing the night vision activate and of course it looks like a spotlight when viewed through the night vision on there other camera. I hope that makes sense....
FlatBugger,
What happens if you manually toggle the spotlight on and back off? Does the spotlight turn off? Do you continue experiencing the same behavior?
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
