The biggest issue is the nearby wall reflecting light (the night vision IR) back to the camera, causing the autoexposure to darken the image. I'll wager that rotating the camera a bit to minimize or eliminate the wall from view will fix the problem.
From what I see from your images, the settings image isn't using night vision, just ambient light. I'm not sure if that's normal but I'd guess so.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
receipts
totally frustrated
VMC2030
VMC2030-100EUS
